Wiring
Discussion in '1955-1959' started by cosmo1957, Mar 11, 2007.
  1. cosmo1957
    cosmo1957 Member
    Cambridge Canada
    Bought the Chevy Duty wiring harness for 55-57 with alteranator.
    Anyone have any idea how to wire in a fuse for the main power (think I know..just checking) and how to eliminate change to suit the HEI ignition?
    It would be great to know for sure before I melt the harness !
    Shawn
  2. cosmo1957
    cosmo1957 Member
    Cambridge Canada
    Anybody ?
    Surely somebody has done wiring before with the same harness ??
    Cheers
    Shawn
  3. Contrinador
    Contrinador Member
  4. coilover
    You can put a fusible link wire where your main feed wire hooks to the solenoid, it comes in different amp ratings. The HEI uses a straight 12v so if the harness has a place for a ballast resister jump across that of if it has a resistance ignition wire run an auxillary wire to bypass it.
  5. jwdutton
    jwdutton Member
    Billings
    I used this same harness. I didn't wire a fuse for main power but the fusible link suggestion is right on. What I did for the resistor was connect both spade ends to the same terminal bypassing the resistor.
    I did set up relays for the headlights (you have to relay both the high and low beams) and I also set up a rely for the HEI. HEI will pretty much suck all the voltage you can give it. It runs best around 16-19v which is why I added the relay.
  6. cosmo1957
    cosmo1957 Member
    Cambridge Canada
    Did you have 1 or 2 wire going to the starter ?
    I am still struggling a bit....... I just ran the + coil wire direct to + side of HEI
    I got it running , but no accesories are polugged in yet......I am afraid of frying it !!
    Shawn
