gear selector hanging up
Discussion in '1947-1954' started by alabama1950, Apr 25, 2007.
  1. alabama1950
    alabama1950 Member
    need some advice, `1950 column shift, gear selector works and works and works and then will get hung up in neutral, i raise the hood, mess with the levers on the steering column and it again works, no rhyme or reason or pattern to why or when or what gear i was last in, any ideas and should i replace the lever assemblyThanks in advance for the help.
    Also i have an oil filter on my engine cartridge style and an old man keeps telling me that there aint original they didnt have them back then,
    i think it was an option as its posted on the option listing , any input here
  2. Kens 50 PU
    oil filter
    Chevy did not put oil filters on the engines, but did offer them as an accessory. The most popular ones bolted on the manifold. Check on this link to look at a classic example of a Fram. AC made them too.
    www.speedprint.com/Deves50/img/index/latest2002lg.jpg
  3. Kens 50 PU
    Let me clarify. The term "accessory" really should be RPO (regular production option). Chevy offered an oil filter (AC of course) as RPO 237.
    Sticky Shifter
    Look in older posts under " square Shifting " or " Posative Shifting " , maybe " floppy levers " as I've covered this in detail .
    Many folks didn't have the $ to afford the oil filter , as it's a by-pass typ you cannot use a spin on on your 216/235 engine , they were fitten at the factory
    (' RPO ' ) dealer _and_ after market , various brands , keep it , use it and change it . NAPA/Wix sells the filters cheaply .
  5. alabama1950
    alabama1950 Member
    Thanks Ken and Nate the photo you sent is exactly what my oil filter looks like, also the horn that i was asking about is the same also
    Any idea on the correct replacement part number for the cartridge
    Take care
  6. alabama1950
    alabama1950 Member
    Nate i found your previous discertation on square and posative shifting and repair ideas and printed them out, now im armed to go do battle ,thanks for the details
    Oil Filter P/N's
    Lesse.....:
    NAPA 5" (AC typ) # 1100
    or if it's a FRAM 8" , NAPA P/N # 1503
    For WIX just add a 5 to the front of the part number .
    Remember to wipe all the sludge out of the cannister with clean rags...
    I hope this helped .
  8. sloromon
    sloromon Member
    Phoenix, AZ
    i had A LOT of sludge at the bottom of mine. i filled it with some simple green and let it sit for a while before cleaning it out.
    jon
  9. alabama1950
    alabama1950 Member
    Hey Jon killer truck there what is that color named and what did you paint the interior and what is your seat color scheme,
    nice website too, good luck with the art,my boy was just in here learning to play bbking the thrill is gone, we jam alot
    take care
    Ken
