Gas tank sending unit replacement
Discussion in '1947-1954' started by alabama1950, Apr 26, 2007.
  1. alabama1950
    alabama1950 Member
    Need some advice from someone whos been there done that,
    I got a replacement gas tank sending unit and this one has
    a pvc coated wire from the float bulb up to the sensor housing
    that will be submerged in the gas in the tank.
    the original one had a metal rod that went from the bulb to the sensor housing, will this pvc sensor wire hold up to being submerged into the tank and is there a fire/spark issue with the wire going down into the tank
    THanks for the education you all have been giving me
    Ken- the handsome one from alabama
    It'll be fine Handsome Ken ; :rolleyes:
    I used to worry about it too but I've never had one blow up yet and I've seen quite a few melt that wire.... :confused:
    Remember : ground the sender lead at the tank to drive the gauge to empty,
    this will show you everything else is working O.K. .
    Often the gauge head isn't well grounded to the dash , adding star typ lock washers to the four gauge pod to dash studs will help as will stainless steel or brass nuts ~ cheap too .
    Add a ground wire from one of the tank sender screws to the frame or the body , this helps accuracy .
  3. alabama1950
    alabama1950 Member
    Nate
    okay i feel better about the wire in the gas tank when you say you ve seen quite a few melt that wire, do you mean that they wont last long with the gas eroding the plastic coating and shorting out the wire?
    Take care
    Ken
    No , either some boob connects 12 volts to a 6 volt truck or the gauge head dies of old age in such a way it sends full current to the sender and it melts .
    I forgot to mention : when you add (or replace) the tank sender ground wire , use a new stainless steel or brass screw so the repair keep on working...
    I always like to hunt up some cheese head screws as they look ' original ' , I'm not overly fond of the Clutch head ones GM used .
  5. Zig
    I'm not overly fond of the Clutch head ones GM used .[/QUOTE]
    Ouch- Hey Nate- these are real tears here!
    Sorry , I was just being honest :eek:
