New Radiator
Discussion in '1947-1954' started by 6400chevy, Apr 3, 2006.
  1. 6400chevy
    6400chevy Member
    Valdez United States
    Should I get a new radiator for my truck. It has an inline six 216 and will the radiator keep the coolant cool enought without over heating or should I get one for a v8?
    'Andrew'
    6400 Chevy
    Valdez, Alaska
    The stock radiator is plenty big enough to cool even a big block Chevy V-ate .
    Take it to a reputable radiator shop where they'll unsweat the top tnak and rod it out , if you look at the top tubes you'll see the crusty stuff they'll wire brush off . have them change the filler neck
    so you can add a pressure cap , not over 7 Lbs. though .
    If you look in the filler neck and it looks clean , you can fill it with white vinegar and let soak to dissolve the depostis @ home..
