Disc brakes for 4x4 front end
Discussion in '1967-1972' started by AV8R, May 19, 2007.
  1. AV8R
    AV8R Member
    Does anybody know if you can get a disc brake conversion for a 69' 4WD front end?
  2. nerfherder78
    nerfherder78 Member
    Fairfield, CA
    I believe you can just use the front end from a '71 to '87.
  3. chevyholic
    chevyholic Member
    St Joseph, MO.
    nerfherder78 is correct, you can bolt in any 71 to 87 Dana 44 or corporate 10 bolt axle. Since your truck is a 69 you have a closed knuckle axle and although it may be possible to fab up a convesion you will be much better off finding the later model axle..much easier to find parts for and also a much better turning radius over the closed knuckle axle.
    Also the reason I left out the 1970 axle is because it is a 1 year only axle..open knuckle but has drum brakes, these can easily be converted to disc using oem parts.
