brake and abs light on 02 s-10
Discussion in '1999-Present' started by dubbin2, Aug 15, 2007.
  1. dubbin2
    dubbin2 Member
    west jordan utah
    i can not figure it out does not pull codes and only does it once in a while
  2. drabo
    drabo Member
    Patrick AFB, Florida
    Pull the rotors and make sure nothing is interferring with the ABS sensor. Try unpluging the sensor and hook up a volt meter. Then rotate the rotor and it should put out a voltage. Correct me if I'm wrong.
