283 mans 1966 c-10 shortbed fleetside progress
Discussion in '1960-1966' started by 283 man, Sep 26, 2007.
  1. 283 man
    283 man Member
    Bentonville,Arkansas
    Got a few more things done on my truck put on the 4 barrel intake manifold, put on crome valve covers got the 350 turbo transmision in crossmember in with transmision mount and also got drive shaft back in .still got to hook up floor shifter mount:rolleyes:.slowly getting it,try to get some more pictures in couple of days.:)doing work by myself because thats the way I want it:D.
  2. 62 short step
    62 short step Member
    Greenwell Springs, La.
    Can't wait to see pics!
  3. 283 man
    283 man Member
    The 283 starting to come to live!!!:D
  4. dijoo
    dijoo Member
    Belgium-Antwerp-Brussels
    Yeah 283man thats gooing well ! :)
    Can you please tell me witch oil you put in it and how manny liters.
  5. 283 man
    283 man Member
    Thanks:). be going with 10-w 30 weight since it doest get really cold here. the brand probably Castro oil gtx.
  6. 283 man
    283 man Member
    Its right at 5 quarts of oil got be right on full mark not over or under,I always check and double check never hurts to be safe than sorry.
  7. dvalentine
    dvalentine Charter Member
    Sacramento
    5 quarts = 4.73 liters
    Val
  8. dijoo
    dijoo Member
    OK thanks 283man and Val ! ;)
  9. truck_oldschool
    truck_oldschool Member
    hey watch your valve cover screw hold downs those things love to come loose and leak like a sive so be careful
  10. 62 short step
    Yea thats what mine are doing, can't stand it. I need to get some bolts to put back on mine.
  11. 283 man
    283 man Member
    more progress on the 66
  12. 283 man
    283 man Member
    The bed on my 66 chevy is off my other 1966 chevy that I got off (62 short step) its a lot straight than the one I had on there before just got to primiar it black like rest of the truck.
  13. rsibley
    rsibley Member
    Milledgeville,GA
    Hi I'm new to this site and was just looking at some of the pics of everyones trucks. I'm in the process of building a 65 myself. As soon as I figure out how to post pics I'll do so to see what everyone thinks. I'm building a 383 for the truck and was wanting to know what headers you used, were they for a 66 or another model? rsibley
  14. 283 man
    283 man Member
    Welcome to the form.To answer your question they came on a 350 crate motor out of another 66 chevy truck that I bought off a good friend thur here.they are for different model not for sure what year the 350 motor is?
  15. rsibley
    rsibley Member
    Milledgeville,GA
  16. rsibley
    rsibley Member
    Milledgeville,GA
    Thanks, It's good to be able to talk to others with the same intrest. I'm sure I'll have alot of questions thru all of this. I've got a long way to go.
  17. 66 KUSTOM
    66 KUSTOM Member
    SALEM OR
    They Look Like Hooker Headers That Are Built For Our Years Of Trucks, 64-66. Small Block Chevy. You Can Get Them At Jegs For About $150.00 Thats What Im Running On Mine, But With Coating.
  18. dvalentine
    Sacramento
    If you plan on lowering the truck consider 3/4 Shortie headers. Full length headers tend to drag the collector over driveways, speed bumps, etc. The result is the bottom of the collector being shaved off, sometimes right up to the bolts.
    The 3/4 length will allow the exhaust to be tucked up under the truck, and out of harm's way.
    Val
  19. rsibley
    rsibley Member
    Milledgeville,GA
    I'm putting 2 1/2'' drop spindles on it. Do you think that's low enough to drag? I'll be lowering the back about 3. I just like the way full length headers sound.
  20. 283 man
    283 man Member
    I wont be lowering the truck so going to stick with these headers,I think they are hooker headers I like them even though their not coated. :D
