erratic dash gauges
Discussion in 'General Chevy & GMC Pickups Talk' started by bikernut, Apr 6, 2006.
  1. bikernut
    bikernut Member
    Bennington United States
    the dash gauges on our 1986 K2500 has some very erratic gauges, going all over the place then settle down and then start pinging around again, I have check the ground and it is good. Is the some sore of resistor in this as I don't see one when removing the gauge cluster?
  2. truck_oldschool
    truck_oldschool Member
    check your grounds and do a back probe would be a good start and fuses
  3. Pontiac1976
    Pontiac1976 Member
    Ontario, Canada
    I agree will this
    or a gound that is not makeing contact all the time so it loose good some times.(bumps in the road, closeing the door, engine rev or idle, shifting in gear or out of gear.)
