I Need A Rear Main Seal!!!!!
Discussion in '1947-1954' started by flwpower, Nov 15, 2007.
  1. flwpower
    flwpower Member
    I have a a 1952 GMC 1/2 ton that needs a new gasket for the main oil seal. Problem is that the engine got changed sometime before I got the truck although I thought it was the original. GMC sent me this rope seal which was not the right one, and even thought I have the engine number LA0226993, I can't locate a place to get this seal. Does anyone know a place I can look to find this?
    flwpower
    Determining GMC Engine
    O.K. , look under the hood , at the _right_ side of the engine , behind the distributor and slightly below , there's a machined flat pad that'll have the engine serial number _stamped_ into it , once you scrape all the grease & yuk off it ~ the first THREE digits will tell you what displacement the engine is .
    Posting the entire serial number here will allow one of the parts book guys to research the model and year engine you have , they're often changed and occasionally there's a Chevy engine in there , always if you have a Canadian built GMC .
    Once you find the correct engine size , I'll look in my gasket book for the correct part number .
    OBTW : WELCOME ! ;)
  3. flwpower
    flwpower Member
    I need a rear main seal!!!!
    I did post the number on the engine block, it was LA0226993. How can I now find out what type of engine this is?
    Peter
    Hi Peter ;
    Where exactly was this number found and is it raised ? .
  5. flwpower
    flwpower Member
    LA 0226993 If you send me your email I can send you a pic of the engine. mine is flwpower@aol.com
    Peter
  6. flwpower
    flwpower Member
    It was found right under the distributer cap, a little left
    Post Pic HERE
    You can post it here and more folks will be able to see it , respond better .
    Or , you may send it to me in a PM .
  8. flwpower
    flwpower Member
    Take a look, tell me what you think
    this is the engine, tell me what you think.
    Peter
    Small Picture But ,
    That sure looks like a dressed up 235 Chevy engine to me .
    If so , It'll take a common Rope Seal , when I get beck next week I'll look up the Victor / NAPA part number for you , it's entirely possible both 235 & GMC engines use Rope Seals .
    Was your truck made in Canada perchance (build info on VIN tag on driver's doorpost) ? if it was , it'll have a 235 in it , Canadian GMC's use Chevy 235's . those wily Canuckians)
    Obtw :
    I think it looks GREAT ! .
    I like the GMC typ oil filler cap built into the Road Draft Tube , I thought your Jimmy engine should have an oil filter on the right side near the oil filler..? .
  11. flwpower
    flwpower Member
    Nate, GMC sent us a rope seal but that was not the part and my repair guy has no idea what it is. I know NOTHING about this truck, got it on ebay as just an extra to tool around my island with and take things down to my boat. Figured it would be a cool novel truck to have. The seal that came off it was a rubber one not a rope one that is why we are having problems.
    As far as the oil filter, I have not a clue. If this was a Porsche, I could tell you everything about it. =0) ptruck2.jpg
  12. vwnate1
    Seal Identification
    Well ;
    If it's a rubber seal with a metal rod backing , it'll have a part number moulded into it and this should be listed in the Bower BCA bearing & seal master catalog.....
    You might need a magnifying glass to read the part number....
  13. flwpower
    flwpower Member
    Thanks for all your help, I think we got it now.. It only took 6 months..lol
    Seriously, you were a big help thanks!
    Peter
