Timing Question 55 3/4
Discussion in '1955-1959' started by gafcob, Sep 18, 2006.
  1. gafcob
    gafcob Member
    Westminster Colorado
    Does anyone know where the Timing mark on my 55 3/4 6 cyl. is? The Resto book and truck manual says it is a steel ball on the Flywheel..How do I find this? Its driving me Nuts...Thanks Mike Gaff gafcob2002@aol.com
  2. step1958
    step1958 Member
    rose oklahoma
    stand in front of the truck look back by the distributor on a 235 there is a hole in the bell housing look in there and you'll see it! looks more like a big dot on the fly wheel
    Ignition Timing Marks , 235 & 261
    It's a small balll bearing pressed into a hole in the flywheel .
    If you look just above the starter motor you'll see a window with a pointer , the idea is : slow the idle down to below 600 RPM's and loosen the pinch clamp at the base of the dizzy a little bit , turn the dizzy untill the ball lines up exactly with the pointer ~ any backlight makes this job nigh impossible , I use a large scrap of cardboard over my back to provide sufficient shade .
    There must be _NO_ vacuum signal to the dizzy when the enging is idling ! .
    Near this ball bearing will be stamped in either a chevron or a triangle , this is the TDC mark and if you have an advance typ dynamic timing light , use this TDC mark to set the all in timing to 32° ~ 34° BTDC for increased power and better fuel milage too .
    Dwell goes to 33° and is best set by removing the spark plugs and running the starter whilst you watch the dwell meter and adjust on the fly ~ this way you adjust for dizzy wear .
    Of course you know you cannot possibly adjust the timing accurately untill the valves have been adjusted , engine hot of course .
