i need to know how to wire the 4 side maker lights . there 2 are 2 wires from the pig tail where do these wires tie into thanks
one wire to ground, one wire to running lamp circuit, doesn't matter which. You may have to use a test light or meter to locate which wire is the park lamp circuit, I can tell you that in the back it will be the brown wire in the four wire harness going to the tail lamps, not sure about the front, but start with the parking lamps
For something different, hook the hot wire into your turnsignal wire and they'll blink when the signal is activated. Looks good and offers more of signal when turning!
