transmission blues
Discussion in '1960-1966' started by oldblue64, Jan 10, 2008.
  1. oldblue64
    oldblue64 Member
    Hi everybody, my 64 chevy step side has a 350 engine,and the 3-speed manual trans.My problem is the trans pops out of 3rd gear while going down the road.It just started doing this.I've tried adjusting the linkage,but it doesn't help.Iwas told the sincrolnizer is out.Do you think this is what it wrong ?Anybody have any ideas ?Thanks for any help.
  2. 283 man
    283 man Member
    Bentonville,Arkansas
    You could allways change over to a automatic transmission 700r,350turbo,2peed powerglide or even a 4 speed grany low lots of different ones out there...:rolleyes:
  3. dvalentine
    dvalentine Charter Member
    Sacramento
    What you described is typical of a syncro going out. Only a trans shop will know for sure.
    Val
  4. joe231
    joe231 Member
    Norman, Ok
    I second what Val said
  5. 283 man
    283 man Member
    It would be best to let a trans. shop look at it first as DVal.and Joe231 are saying just to know for sure whats going on.
  6. Hotrodkilroy
    Hotrodkilroy Member
    Wilton,Maine
    I had the same problems with my 3 spd also ended up being a bad syncro between 2nd and 3rd. i also did have a tranny shop fix it cost my less than $100 they had all the tools. KIlroy was here
  7. oldblue64
    oldblue64 Member
    Thanks everybody for the info.I'm not sure if I'll fix it or just go ahead and change it to the automatic.Thanks agian,old blue 64
  8. 283 man
    283 man Member
    good luck whatever you decide to do.
