Hey
Discussion in '1960-1966' started by aftershock, Jan 12, 2008.
  1. aftershock
    aftershock Member
    Well guys I'm back if you remember me from about a year ago. I lost interest in doing to restoration because I was unsure of my mechanical and metal skills etc.... But I took a few classes on welding and "Ag Mechanics" which we tear apart a small engine and put it back together, so I now think I'm ready to take on the project. It is a 1966 GMC C20. 4-on-the-floor with the 250 engine.
  2. Hotrodkilroy
    Hotrodkilroy Member
    Wilton,Maine
    Im glad to see u havent given up on your project. Im not gods gift to bodywork so I joined a Club and got help from others members. We all bring talents. My expert is wood and mechinal. Kilroy was here!!!!
  3. 62 short step
    62 short step Member
    Greenwell Springs, La.
    Welcome back!! Glad you took some classes, they should help alot! Now get to work! :D
  4. 283 man
    283 man Member
    Bentonville,Arkansas
    welcome back!!!:).
  5. aftershock
    aftershock Member
    Thanks for the welcome. I went and looked the truck over today again and found some bad rust spots becide the gas tank in the corners of the cab. I looked for about a 1/2 hour and haven't found any patch pannels for it, anyone know where I could find some? Also another question I had was with the radiator. Will about any radiator work from a car with the same size engine or bigger if the radiator fits in the current mount?
  6. 62 short step
    Any v-8 rad should work if it will fit in the space provided. There are cab corner panels availible if thats what you need. I'l look them up for you.
  7. 62 short step
  8. 283 man
    283 man Member
    not bad price at all.
  9. joe231
    joe231 Member
    Norman, Ok
    I thought he was referring to the back corners of the floor, dunno?
  10. aftershock
    aftershock Member
    thanks, i think that is it. I can't believe I couldn't find it.
  11. Bruno
    Bruno Member
    Your never to old to learn somthing new.
  12. jwart
    jwart Member
    cab corners
    cab corners just did mine with the rockers & floor pans. now welding in new bottom inner & outer doors. check truckandcarshop.com i used their tank conversion setup very happy. jw
