Column Shifter shot
Discussion in '1967-1972' started by The Pack Rat, Jan 17, 2008.
  1. The Pack Rat
    The Pack Rat Member
    LaGrange, Illinois
    I have a 1971 C-10 pickup. Its all original, but the column shifter is completely shot. I hope to rebuild it, but I can't find parts. Does anyone know of a website that will have what I need?
  2. Big_Eddie
    Big_Eddie Member
    Column Parts
    If Classic doesn't have what you need, you can try www.LMCTruck.com
  3. Paul sherman
    Paul sherman Member
    What exactly is wrong with the shifter?
    The problems I've had with my '69 over the last 21 years is that the shift lever itself is loose where it mounts in the column (the pin hole wears) and the slider to the bottom is sluggish.
    The sluggish/sticky slide is easy enough to fix, though a bit labor intensive. Pull the column out, dissasemble it and grease the sliding collars. Sometimes you can just squirt some spray oil on the lower slide while in the truck and loosen it (easier to have a friend working the shifter while doing so, but I did it myself).
    Loose shifter handle - no good solution yet. I replaced the collar with another, but it's worn as well (the pin keeps working out). At one time I saw a kit that replaced the pin with a self-retaining assembly, but haven't seen it in the last 5 years or so... right now I have a flat machine screw loosely double nutted. Not Pretty, but at least the pin no longer falls out with me holding the detached lever in my hand.
    I've thought about brazing up the hole in the collar to build it back up, but haven't done so yet.
  4. The Pack Rat
    The Pack Rat Member
    LaGrange, Illinois
    It almost won't shift at all. I wont go into 3rd gear,it would for the previous owner but not me and I don't want to force it. The previous owner told me when he bought it 2 years ago it wouldn't go into any gear. He and a friend of his took apart the end of the column (lower end) and I think he said they found a bearing inside was bent. I'm sure he said something was bent. After they found the bent part they straightened it the best they could, put it back together and it was able to shift(short of). That shifter is the reason he sold it to me. It only cost me $900
