Some pictures of my 1950 Restoration
Discussion in '1947-1954' started by Ruger338, Jan 17, 2008.
  1. Ruger338
    Ruger338 Member
  2. Tailgater
    Tailgater Member
    Greene County, TN
    Welcome Ruger!
    I enjoyed your pics. Looks like you started with a fairly solid truck and you are moving steadily in the right direction. It is easy to reach a point where you walk away when one is disassembled. Just hang in there and keep up the good work.
    Gater
  3. Ruger338
    Ruger338 Member
    I do something everyday even if i just go and clean or paint a part or make my next plan of attack.
    Good Job !
    I'm impressed , looks like good work and solid welding .
    Will you be retaining the 216 engine ? .
  5. Melsfine39
    Melsfine39 Member
    Toledo,Ohio
    Nice Truck!!, Nice Work!!, Great pictures! keep'em coming as you get more done.
    Mel
  6. Ruger338
    Ruger338 Member
    Yes I am keeping the 216. I plan on using the truck for sunny weekends with the grandkids. I am converting to 12-volt and as you can see modern radials. Other than that I will be keeping it original looking.
  7. Zig
    Looks like we're about in the same stage. GOOD LUCK WITH THAT! What color are you going to paint your truck? There is a simple paint method you can use using to foam rollers...
