Bolt Pattern change
Discussion in '1955-1959' started by cosmo1957, Nov 4, 2004.
  1. cosmo1957
    cosmo1957 Member
    Cambridge Canada
    I wanna run 5 bolt Corvette Rally wheels on my 57.
    This means new front hubs and a new rear end or axles.
    Any advice on the potential rear end swap ?
    What will fit? Posi would be nice if I am swapping the rear. Or can I just do an axle swap .... ?
    What about front ,,,Any advice would be appreciated, this truck needs to be done by 2005 !
    jrfan@sympatico.ca
    or share post to group
    Between the ditches,, rubber side down !
  2. smoov330
    smoov330 Member
    Peotone USA
    There is a company that makes a 6 bolt rally and can use the same cap and ring..
  3. Bill Hanlon
    5 lug front hubs from 53-54 Chevy car are a direct replacement for the stock 6 lug 1/2 ton truck hubs. I am not positive that the bolt cicle is the same as the Corvette wheels, but I think it is.
  4. VELCRO
    VELCRO Member
    OCALA USA
    just for your info, Chevy made 6 lug rally wheels, I have 4 of them in 10 inch width, they are on my '58 1/2 ton.
  5. Bill Hanlon
    RE%3A Bolt Pattern change
    Attached is a picture of the mid-70's 6 lug Chevy 4x4 (rally?) wheels I have on my 57 GMC. The knock offs were less than $20 for the set of four and have a 1/4" threaded hole on the back side. The "4x4" cover on the hub cap is light weight aluminum and already has a 1/4" hole underneath it. I paid about $25 for the set of four trim rings.
    https://talk.classicparts.com/images/attachments/ctruckwheel3.jpg
  6. Bill Hanlon
    RE: RE%3A Bolt Pattern change
    OK, I'm too dumb to figure out how to do an attachment.
    If you are interested contact me at
    bill.hanlon@compaq.com
    and I'll send the pictures.
  7. cosmo1957
    cosmo1957 Member
    Cambridge Canada
    Thanks for the feedback,, but Can you find me those "cheap" 6 bolt rallys ?
    I have a set now,, but they are not the same a corvette 15 x 8 rims ?
    I can sell the vette ones and buy 6 bolt if anyone is interested ?
    Shawn
