Wheel Cylinder Clamp
Discussion in '1947-1954' started by Larrys 48, Feb 5, 2008.
  1. Larrys 48
    Larrys 48 Member
    Spokane, WA
    Any of you (Nate?) come up with a tool to replace the wheel cylinder clamp made to keep the wheel cylinder from expanding during brake shoe removal? Larry
  2. wschmpn
    wschmpn Member
    clamp
    could u not use a thin wire tie? thats how my new cylinders came in the box.
    Although I have A Pair
    ..I also use # 150 rubber bands , old coat hangers , string , lamp cord , pretty much anything you have handy will do as long as it holdsthe cups from popping out of the brake cylinders .
  4. Ruger338
    Ruger338 Member
    I made a couple out of old Oxy/Acetylene torch stikers cut the ends off and rebent them slightly. They work great and have tension due to the spring.
  5. my515w
    my515w Member
    they make a tool to keep them together. its called a wheel cylinder clamp
