1/2 - 3/4 ton frame differences
Discussion in '1955-1959' started by natew, Dec 2, 2004.
  1. natew
    natew Member
    Klamath Falls USA
    Are there any differences between a 1/2 ton GMC and a 3/4 ton GMC frame, steering, suspension, etc.?
    I know that the axels are heavier and have a different bolt pattern.
    Thanks,
    Nate
    Unfortunately the GMC Master Parts Book only lists whole frames as:
    Group 11.0010 Frame
    Note: Frame Assemblies must be ordered NPN giving full information.
    Specify model and chassis serial number.
    NPN means No Part Number
    Master Parts Book lists all 3/4 ton as model 152 with 123" wheelbase while 1/2 tons are available as model 101 (114" wheelbase) amd 102 (like mine with 123" wheelbase"
    Glancing through section 11 (frame) of the Master Parts Book I didn't see any differences between 1/2 and 3/4 ton parts attached to frames (gussets, plates, bumper brackets, etc.).
  3. natew
    natew Member
    Klamath Falls USA
    Thank you Bill.
