Hot Rod Floor Kit
Discussion in '1947-1954' started by morepower16, Feb 16, 2008.
  1. morepower16
    morepower16 Member
    Houston Texas
    Can anyone tell me if the Hot Rod Floor Kit for the 54 truck is the front and toe boards only or does it include the rear floor as well.
  2. Kevin's 48
    Kevin's 48 Member
    Tn
    How handy with sheet metal are you? If you're pretty handy with it then make your own. It is very simple and you can put a tunnel in it if you're lowering the vehicle. Make sure you use atleast 18 gueage metal. Also put some rolls in it with a bead roller so that it doesn't pop everytime you step into the vehicle.
  3. 5034ton
    5034ton Member
    been there, got the t-shirt
    I installed item 45-901 from CP and it consists of the front floor pans, toe kicks with a trans hump and a crossmember bar to join new front floors to original rear floors. The rear floor is another kit.
    Scott
