Crankcase vent tube
Discussion in '1955-1959' started by 58fleetside, Mar 3, 2008.
  1. 58fleetside
    58fleetside Member
    Boulder, CO
    I have a 58 chevy with the original 235 in it.
    Is there something I can replace the crankcase vent tube with so I don't end up with oil all over my newly redone engine compartment?
  2. azcarman411
    azcarman411 Member
    Rimrock, Az
    Pcv
    You might do a search on a PCV set up for your 235. Theres a thread in the 47-54 area check that out. Chris
    235 Blowby
    Keeping the engine in a sharp state of tune (valves , plugs & timing) plus changing the oil regularly , will greatly reduce oil droplets blown out the road draft tube .
  4. chevymantrucks
    chevymantrucks Member
    Lincoln U.S.A
    change the oil
    Just keep the oil changed and you should be ok.
