55 chevy 2nd series steering column
Discussion in '1955-1959' started by thomascf, Dec 7, 2005.
  1. thomascf
    thomascf Member
    arlington US OF A
    hi,
    ive got a 55 2nd series 3100 pu. i am planning on doing a resto/rod job on it. i am trying to figure out what i could use for a steering column. i am trying to stay away from the aftermarket steering columns (too expensive) and would prefer to use something i can pull off a donor car. can anyone give me any suggestions as to what i can pull on off of, and how i will need to modify the column/truck? thanks, i appreciate the help.
    sincerely
    clark
  2. 58 chevy
    58 chevy Guest
    RE: 55 chevy 2nd series steering co
    You might want to take a look at the 68-72 Chevy/GMC trucks there columns are just the right length and you can find one with tilt and your ignition key is still in the dash.
    Jesse Hazell Chevy Duty Tech.
  3. Mikeyoung3142
    Mikeyoung3142 Member
    A 1972 chevy tilt col. will fit right in there.
  4. chevymantrucks
    chevymantrucks Member
    Lincoln U.S.A
    [updated:LAST EDITED ON Jan-01-06 AT 08:02 PM (CST)]Use your stock one and cut it off the box.Mod it to work with your set up.I did it to my 55 Gmc show truck and people think it looks factory..Good luck....Chevyman
  5. mcarrel
    mcarrel Member
    Mesa USA
    Check out this link from the Classic Truck Shop
    Tilt Wheel / Swing Pedal Brake
    http://www.classictruckshop.com/Tilt_Column_Brake.asp
    >hi,
    >sincerely
    >clark
  6. badass56
    badass56 Member
    athol usa
    im looking for a all metal colum with the tilt option for a 56chey with a floorshift? What have you guys found that works the best in this type of application.I have a colum out of a 88 blazer but i do not like the plastic covers so im looking for an older metal colum
  7. JB59
    JB59 Member
    Beaumont USA
    if the steering wheel off a 68-72 chevy will bolt in a 55 2nd Series, it is safe to think that the same steering column will work in a 59???
  8. 57 restomod
    57 restomod Member
    Thomas, what are you hooking the column too? original box?, newer ifs conversion? I'm in a similar situation. I've done a Volare ifs clip. I haven't got a column yet but I've gathered some suggestions from what others have used that include:
    late 70's gm van (tilt, no key, no gearshift, 35" long)
    80's gm van
    79 pontiac car
    83 grand prix
    68-72 gm truck ( tilt and no key)
    I guess whatever works best will depend on what front end you have, whether you want a column shift and whether you want a column key or not. Tilt is a good thing because you can tuck the column up tighter under the dash and tilt the wheel down. I guess some newer columns will also have cruise and wipers on the signal you may or may not want.
    Murray
