Free tool
Discussion in '1947-1954' started by coilover, Apr 1, 2008.
  1. coilover
    OK, it might cost you 42 cents for a stamp to send a drawing. We have a problem with reproduction window felt channels wanting to bend unevenly and the sides flaring out so the window trim ring is hard to put on. I fabricated this from scrap wood and it works great. The one pictured is for a 47-50 so the center piece is 0.350 to fit the metal frame around the window. For the 51-55.1 the center piece would be 0.250 to fit the glass. A plastic hammer seems to work the best to form the felt channel to the pattern--note the very even wrinkles on the sides of the channel with the 90 degree bend.
  2. ol' chebby
    Nice.....someone has been thinking.
  3. Kens 50 PU
    Now that is slick! That ranks up there with sliced bread and pockets on a shirt. Thanks for sharing that Evan!
    Even ;
    Your high standards of work constantly impress me , keep up the good work .
  5. Larrys 48
    Larrys 48 Member
    Spokane, WA
    Way cool
    Evan - I'm glad I haven't started that project yet. I was just planning on rolling the window up to form the beast, but this looks like a sure fire way to control the warping. Thanks, Larry
  6. Dadboughtit
    Dadboughtit Member
    Rocklin, California
    Brilliant!
  7. cochran
    cochran Member
    Denver
    Is there any way for you to post the template so I may make one at home? If not I would gladly send a stamp for the template. Thank you!!
  8. coilover
    I wish I could but I am a computer cave man. Would be glad to sketch one up and send it by snail mail. Here is a quick discription; if it isn't decipherable let me know and I'll send a sketch.
    (1) The center piece is a copy of the glass
    (2) The pieces on either side of the center piece are 1/2" smaller and the total of the center piece plus the two pieces attached to it equal the total width of the felt channel.
    (3) The two outer pieces are the same size as the center piece (window glass).
    By looking at the picture I think you will see this but if it gives a problem let me know. I have a 51-55.1 window I can measure and give you the dimensions.
  9. Zig
    Evan~ that saved me a bunch of improper language use, I'm sure. I would have never been able to see the problems I would have faced until it was too late! Thanks for the heads-up and a simple way to solve it.
    BTW, I love the coups in the background! What a shop!
  10. Larrys 48
    Larrys 48 Member
    Spokane, WA
    Window channel
    Thanks again Evan for the "free" tool. I see someone else needs it. :cool:
