Outside Mirror Place
Discussion in '1947-1954' started by willardgreen, Apr 2, 2008.
  1. willardgreen
    willardgreen Member
    Dixieland!
    Hi folks, I just bought a pair of original style mirrors from Classic Parts and don't know the exact location to drill the holes. Needless to say I only have one chance to do it right. There was a accessories manual online that disapeared. Any help would be appreciated.
  2. Tailgater
    Tailgater Member
    Greene County, TN
    Willard,
    If you will look under the dash you will find that the steel is double thickness where the mirrors go and that the inner layer already has the holes cut out. I put masking tape on the outside to keep from marring the surface, went inside and drilled a hole from the inside out through the middle of the hole in the inside layer of metal. Then I went outside and used that hole for the pilot to drill from the outside in with the proper size bit. With the masking tape in place I mounted both mirrors without a blemish.
    Gater
  3. Kens 50 PU
    Here's a picture of what Gater was talking about.
  4. willardgreen
    willardgreen Member
    Dixieland!
    Thanks tailgater. I did not have a clue.
  5. willardgreen
    willardgreen Member
    Dixieland!
    Thanks for the picture Ken
  6. Tailgater
    Tailgater Member
    Greene County, TN
    That's what it's all about.
  7. Kens 50 PU
    Yeah, what Gater said!;)
  8. Larrys 48
    Larrys 48 Member
    Spokane, WA
    '48 - no ho
    Ken, thanks for the picture.
    FYI - my '48 has no such prep. I thought maybe I wasn't looking in the right place, but after removing the glove bax and reviewing you picture, it just ain't there...Larry
    No Guide Holes
    Wow , that's wierd .,
    Next step is to buy the acessories manual , they should be in there .
    Or , go to some shows and take tape measure and paper & pencil , measure and make up some templates off other old trucks there .
    There should be guide holes on the inner panel on both sides .
  10. ol' chebby
    They are about the same place as the one on the driver's side holes in the cowl. Hold them up and you can see where they fit properly.
  11. mel 55_1
    mel 55_1 Member
    England
    My 55 had nothing inside the cab to help either - as you say Larry, just ain't there.
    In the end I measured up exactly where the holes were on the driver side and put new ones through same place on the passenger side. The mirrors line up perfectly - and I'm driving on the left so I need that one over on the right.
