Tail light in bedroll ?
Discussion in '1947-1954' started by buci99, Jun 8, 2008.
  1. buci99
    buci99 Member
    I am wanting to install a small tailight in the ' bedroll ' and use as a signal light, this is on top of bed -rear, in the approx 1 1/4" hole in the bedroll, does anyone know what light would work ?
    Bill
  2. sweet50
    sweet50 Member
    A R I Z O N A
    They make bed cap lights just for that application. I just can't remember off the top of my head who sells them.
  3. Fla54Chevy3100
    Fla54Chevy3100 Member
    Central Fl.
    Several vendors sell them for about $110.00 a pair. Check out my version of cheap/quick and see if it might work on your truck.
    http://rides.webshots.com/photo/2028477940090459121hwwtUe
    The next picture in the album shows what I used for the light body. Was going to use an LED but found a straight conventional bulb was just as bright. I use the rail light in conjunction with a lower mounted LED as turn signal lights.
    Dave
  4. Fla54Chevy3100
    Central Fl.
    If you want your lights totally inside the bed rails....a chunk of tubing (bass boat seat extension diameter), a couple fat O-rings and a little disc cut out of tail light repair kit and sandwiched between the O-rings will let it slide right inside! Add a bulb receptical and you're in business.
    Dave
    Save the $110. for your next tank of gas!!!!
    What Dave Said
    ....Then slide it in about 2" and it'll be invisable until you flick on the turn signal.....
    Use an LED lamp here to really get attention when you're making a turn .
  6. buci99
    buci99 Member
    Good Ideas
    Thanks a lot, GOOD IDEAS
  7. buci99
    buci99 Member
    Tail light
    I used some of your ideas, got bulb recepticle and bulbs from NAPA, went the hardware and got some plastic plumbing fittings that the recepticle slid in snug, epoxyed it in, outside diamater of fitting was 1 1/2" so it fit in bed roll snug with some grinding, also epoxyed that in bed roll, ran a screw through bed roll into metal bulb recepticle for grounding, used an amber bulb. Bulb is recessed approx 3/8", No lens, will see if this holds up, for now it works great !!
    BILL
  8. Zig
    Go, Bill!
    Outstanding! Thanks for the very descriptive how-to instructions! I'm willing to bet you won't be the only one who does this!:cool:
  9. Fla54Chevy3100
    Central Fl.
    I see just one problem......you've got the whole thing so securely installed in the bed rail that you just can't pull it out and show the guy who asks about it. I love to see the look on their faces when they see the green "rainbird" label.....you can actually hear the wheels turning in their heads!!!!!
    Dave
  10. buci99
    buci99 Member
    Light
    YEA, IF IT'S GOTTA COME OUT, I'LL NEED A HACKSAW :eek:
  11. penniwinkle
    penniwinkle Member
    Queen Creek, Arizona
    I did this on my 51. I ordered some 'caps' from CP (think they were called the bed-roll caps). They just push in. I driilled a hole in each and bolted in 'LED bolts' (I chose the red ones). I then wired them to my brake and signal lites...pretty easy. They look great at night...the LEDs are really bright.
  12. sweet50
    sweet50 Member
    A R I Z O N A
    Another good idea.
