frame swap?
Discussion in '1955-1959' started by tez, May 20, 2005.
  1. tez
    tez Member
    memphis usa
    what new model frame will fit under my 55 long bed with little to no mods?
  2. JFK
    JFK Member
    KRUM US
    HEY DO YOU HAVE A 2ND SERIES OR FIRST?
  3. tez
    tez Member
    memphis usa
    2nd long bed 1/2 ton.
  4. coilover
    If you find such a frame myself and a thousand others will chip in $10 apiece and give you a $10,000 reward.
  5. pavan
    pavan Member
    1980 chevy silverado 1/2 ton thats what i used on mine but i took 8 inches outta the frame wheres the 10,000
  6. coilover
    If you call fabbing cab mounts, bed mounts, core support mounts and changing from in back of the axle steering to in front, " little or no modification" you deserve it. Taking 8" out of a frame is a biggy for a guy that probably doesn't own a torch or a welder.
