wire harness with cloth covering
Discussion in '1947-1954' started by Guest5979, Jul 18, 2008.
  1. Guest5979
    Guest5979 Guest
    anybody know where to get the wire harness with the cloth covering??
    i am in the so cal area.
    thanks
    Robert
  2. shankamoto
    shankamoto Member
    Missouri
    wire harness
    You might try this co.
    YNZ'S YESTERDAYS'S PARTS
    333 E STUART AVE A , REDLANDS CA. 92374
    909-798-1498
  3. brit 50
    brit 50 Member
    Essex England, the motherland
    Cloth tape
    Over here you can get cloth tape, either self adhesive or not, and you can wrap it yourself, its hard to get hold of but a few vendors do keep it. Just a thought.
  4. Guest5979
    Guest5979 Guest
    wire harness
    thanks for the tip
    i called ynz they are not to far from my house
    and they want over $600 for harness with cloth cover.
    WOW.
    thanks
    Robert
  5. Kens 50 PU
    I'm with you, Robert!
    Chevsofthe40s has them too and they are $580+. I thought I wanted one for my truck too until I priced them! I'm very happy with my cheapo:D wiring harness from CP!
  6. Guest5979
    Guest5979 Guest
    wire harness
    I think I will do the same here KEN
    BTW you have an awesome truck
    Robert
  7. Kens 50 PU
    (blush) Thanks (blush)
    I think you'll be impressed with the wiring harness from our host! My truck is a 6 to 12 volt convert with a 12 v generator, turn signal added w/ front parking lights used for the turn signals, and the CP harness was a dream to install!
  8. Guest5979
    Guest5979 Guest
    MY truck is 12v turn signals parking light blinker combo
    and 12v gen too.
    just all oem cracked and faded wire.
    i went back and looked at your firewall and it looks good.
    nice and clean.
    Robert
    Cheapo Harness
    Robert ;
    I have the Chevy Duty $100.00 Taiwanese harness in my '49 for some years now (over 10) and it's still working fine .
    The terminals are really delicate so you've gotta hold 'em with one hand as you tighten the screws else they'll rip right off (guess how I disvovered this ?)
    I highly recommend this basic harness , maybe the single upgrade one for alternator and turn signals , I have both on my stock typ harness , only had to run one additional wire for the right rear turn signal/brake lap circuit .
  10. Guest5979
    Guest5979 Guest
    Yep I will go that route too but have a ton of other things to do first.
    have to go to the truckshop tomorrow to take back wrong parts.
    finished my floors now trying to get right parts for clutch and all that stuff
    so i can get eng/trans back in.
  11. vwnate1
    Keep On Truckin'
    One step at a time Robert , you're doing well .
