What to use?
Discussion in '1947-1954' started by Chiro, Jul 24, 2008.
  1. Chiro
    Hi guys,
    What type of glue is used to install the cowl vent rubber seal? Same as the door weatherstrip?
    Yep ;
    Good old 3M ' Gorilla Snot ' ~ the yellow stuff .
  3. Chiro
    Gorilla snot
    I am familiar with the term but unfamiliar with the product. Does it have a "real" name???
  4. Kens 50 PU
  5. ol' chebby
    weatherstrip adhesive
    3M Gorilla Snot
    Notice it comes in black and yellow , you want the yellow stuff as it sticks better and lasts forever...
  7. 51 HHR
    51 HHR Member
    New Egypt New Jersey
    In the airplane or aviation industry we use 3M 1300L it is the yellow stuff I think Nate was refering to We usually dilute it with toluene or MEK 1-1 or 50 50 how ever you want to say it then apply two of these thinned coats to each surface after each prior coat dries. After the second coat dires we wet or really Dampen a rag with either the MEK or Toluene and activate the stuff a little ata time working the seal into place this technique works pretty good but becareful once you reactivate and touch the two together they will not come apart with out taking the paint or teh rubber apart oh also we mask the area we dont want teh glue to be on just makes clean up easier and application faster as you dont have to be as neat with your brush
    Bill
  8. Zig
    So I can assume you used Gorilla snot on your truck? No doubt I will since I'm here in the "Home of the Gorillas!";)
  9. 51 HHR
    51 HHR Member
    I haven't used it on my truck yet but that was the plan for the door seals
    though I have never heard of it coming in black as Nate suggested?
    Bill
  10. 1952Bowtie
    1952Bowtie Member
    Spokane, WA
    Zig, I know you're probably on a budget, but you're not going to try to extract it yourself are you? I want some pictures!
    Bob
  11. vwnate1
    Black 3M Weatherstrip Adhesive
    ..Is crap .
    Shyte .
    Useless .
    You'll be sorry if you use it.....
  12. brit 50
    brit 50 Member
    Essex England, the motherland
    I tried to get some fresh but the gorillas now have a nice supply of brit snot!!!
  13. Zig
    I might try the huge concrete ones out by the stadium...:rolleyes:
  14. 1952Bowtie
    1952Bowtie Member
    Spokane, WA
    Snot extractor
    Is this what you use, or is there a special tool for that?
    Bob
