heater/AC trouble
Discussion in '1967-1972' started by 69longhorn, May 3, 2008.
  1. 69longhorn
    69longhorn Member
    I own a 69 longhorn with 396;I live in Germany and I need the heater over here!!! Does anybody know how to exchange the heater core; can I seperate it from inside/under dash?Thanks!
  2. fast2act
    fast2act Member
    heat
    :rolleyes:To exchange the heater core you need remove it from under the hood
    Remove the hoses the heater motor and cover. Inside the cover you will see the core is held in with 2 straps this job is not that hard to do just take your time and if you can take photos to help with reassembly.
  3. 69longhorn
    69longhorn Member
    Hi,
    thanks from Germany for Your answer.
    It looks a little more difficult, because my truck has AC. I can´t find any bolts/screws that hold the outer heater-case to the inner heater-case,but it´´s necessary to divide them to reach the heater-core.
    I hope You understand what I mean.
    Thanks again
    69longhorn
  4. Soba_03
    Soba_03 Member
    Heater core r/r
    Well it seems I'm a little late on the scene here. However, it's not that easy to r/r a heater core on these truck. Not difficult mine you but just a pain in the behind.
    I will give you my experience and you can go from there.
    First off pull off the hood, then the passengers side hood hinge. Next your going to have to remove the passengers side inner fender to access all the bolts. This is the reason that almost all of these trucks either don't have the bottom outside bolt not installed or the ear is broken off. once this is done then you can remove the bolts to the blower housing and pull it off the firewall. Once you get it off them you can clean the years of crap stored in your cowl out of there and then remove the clamps that hold your heater core into the blower motor housing. reinstall in reverse order, oh you'll probally find out that almost all of the nut clips for the inner fender will need replaced because they must be soemthing like single use clips, they self destruct after you try and get them out. Replace them know and all is well..
    Hope this helps and sorry that it was late....
