283 or 235
Discussion in '1955-1959' started by suburban hunter, Feb 11, 2005.
  1. suburban hunter
    suburban hunter Member
    [updated:LAST EDITED ON Feb-11-05 AT 09:14 PM (CST)]If one was lucky enough to have a choice. Which would make for the better restoration out of two condition 4 57 3100's? A 283 (180hp) or 235 (140hp)? Anyone have some pros and cons.
    the 283 had a unique engine mount for that year. Why? The overall hp and torque not that great. 23%(stock) But the v8 has more potential
    are there any break down of percentage of production for v8's that year?
    Burned out on the research. and only want to put 6-7k in.here NY, CT,
  2. ljw
    ljw Member
    tucson
    283's are plentiful and very strong.Aftermarket parts for most any 350 will fit,which makes them very flexible.
  3. suburban hunter
    [updated:LAST EDITED ON Mar-25-05 AT 08:10 PM (CST)]cast on the block is
    Vin#v3a57k112204,Block# 3789935, engine code F1113D, Heads# 3814480/k107, manifold#3746826,exhaust 3749965, carb#7020008
    it appears that the engine could of been replaced in 1961
    Carb
    7020008 8 283 1962 A/T Rochester 2-GC
    3789935....283... 61-64...2 (AS FAR BACK AS 1958)
    3814480....283/327.60-67....70cc chambers, 1.72/1.5 valves
    3746829 1958-61
    3749965 1958-61
    f1113d EITHER 58 OR 60
    Don't know if this is original engine or block, It must have been rebuilt in 60-61. Kind of bummed. Does it make any difference?
  4. Larry Bear
    Larry Bear Member
    Sorry this is off the subject... but I have a question for SubHunter... I just got an email from "jrf@suburbanhunter.com"... is that you?
    Larry
    56 Stepside - Daily driver
    Carlisle, MA
  5. suburban hunter
    yes
    hi larry that is my email
    Jay
    just see how you were making out with the restro
  6. Larry Bear
    Larry Bear Member
    OK... just checking... thought it may have been someone lurking.
    Larry
    Carlisle, MA
  7. 58 chevy
    58 chevy Guest
    I ran the casting numbers you have posted and you have a 1961-64 283 small block v-8, and for the heads you have a 60-67 283 or 327 70cc chambered heads.
    Jesse Hazell Chevy Duty Tech.
