cowl vent seal
Discussion in '1947-1954' started by mylow53, Aug 13, 2008.
  1. mylow53
    mylow53 Member
    ok i ran in to an issue with the cowl vent seal did i get the wrong seal or is this how it's supposed to look?
    with the seal in the vent sits real high i spoke to brothers trucks and they think the cork version will do about the same.... any ideas?
  2. Kens 50 PU
    The cowl vent should be flush with the cab. Is the seal moulded rubber? I used a foam rubber seal on mine and had no problems with the fit.
  3. mylow53
    mylow53 Member
    where did you get it? brothers only lists the cork and the rubber versions...
    Thanks for the help
    GT
  4. Kens 50 PU
    Jim Carter's sells them. BTW, you're truck is looking mighty good!
  5. ol' chebby
    I used the rubber from Jim Carter. It has a curved surface that goes to the top. It should lay flat. There is some adjustment to the vent itself in the mount that might tighten it down a bit. I tend to stay away from Brothers....they are expensive. Try our host, truckshop, jim carter and lmc.
  6. Steve Katzman
    Steve Katzman Member
    Seals
    I had the same problem until I realized I had the seal upside down:( The flat part down and the curved part up and then everything fits flush. (I used the molded rubber one from CP and it now looks and works great.
  7. sweet50
    sweet50 Member
    A R I Z O N A
    Is there any paticular adhiesive that works best for best for this seal?
    3M ' Gorilla Snot ' :p
  9. sweet50
    sweet50 Member
    A R I Z O N A
    Thanks ;)
  10. mylow53
    mylow53 Member
    thanks guys i ordered one from Steele Rubber Hank over there said brothers seal was probably from overseas. he says his will be simmilar to the hardness of the door rubber seal.. thanks guys this really helps
    GT
  11. Zig
    Tanks!
    My vent's out right now and awaiting the painter. I appreciate this thread more than you know!:cool:
  12. ol' chebby
    Check this area out for rust. look under the dash and see how it looks. Mine had rust holes and bondo that is beginning to crack out. I am looking a just replacing the whole cowl piece.
  13. Zig
    Been there~
    Mine looks really good. Not as good as Jim's, but pretty dang good!
