I might have messed up!
Discussion in '1947-1954' started by BIG CHEVY 3600, Aug 18, 2008.
  1. BIG CHEVY 3600
    BIG CHEVY 3600 Member
    Dallas
  2. rtnnhazel
    rtnnhazel Member
    las vegas
    wow that sucks. it looks like one of two things. 1. the cab has sagged during reconstruction. 2. you simply mounted the toeboard at the wrong height. what i would do is redrill the holes in the toeboard and measure the dintance from old to new then redrill the holes in your inner fenders with the new measurements. im not even sure if i understand that! anyways i hope this helps- Robert
  3. rix 48
    rix 48 Member
    Not much help!
    After looking at your web shots, I can't see why you replaced the toe board? I need to replace the lower part of mine but it is much worse than I see on yours. Was the new one a little oversize for trimming? Looks like you did a great job getting it in there. Heck, now I need to go look for that brace and see if I'm going to have the same problem. :eek:
    Rick
  4. ol' chebby
    With the mount mounted at the bottom, everything should line up with it. Just re drill the holes. Some of the patch panels aren't quite as accurate as one might hope....
