Radiator swap part ll
Discussion in '1947-1954' started by mobileortho, Aug 20, 2008.
  1. mobileortho
    mobileortho Member
    Hampton, VA
    I'm still looking for a junkyard radiator swap (my budget has been reduced!!) for my '50 and I came across this on Ebay. Its a Modine Radiator for 1978-1980 Ford Granada. The dimensions look pretty close. Looks like other F$#d units might work because the inlet & outlet would be about right if turned sideways. Anyone else considered this?
  2. rtnnhazel
    rtnnhazel Member
    las vegas
    well if it helps what i did was take the entire radiator and the front mount to a radiator shop then i had them reuse the old top tank and retrofit the bottom to accomadate a th350 then replace the core with one that could accomadate a sb350. it only cost me $140. dont know if it will help but its worth a shot- Robert
    Agrenada radiator was in my '49 when I bought it , kinda small (too thin) but it worked O.K. I guess ~ I threw it away , NO ONE wanted it after I found an original and had it re-cored for $250.00
  4. BIG CHEVY 3600
    BIG CHEVY 3600 Member
    Dallas
  5. sweet50
    sweet50 Member
    A R I Z O N A
    If you turned that on its side then the filler neck and cap would no longer be on top but on the side as well.
  6. ol' chebby
    I just ordered a desert cooler from Jim Carter and was done with it.....
  7. sweet50
    sweet50 Member
    A R I Z O N A
    Do you have a part number for that?
    I found the web site
    w w w. o l d c h e v y t r u c k s . com
    The Desert Cooler Radiator
    Is made by US Radiator Co. in Los Angeles , Ca. (actually Vernon IIRC) so if you order direct from them , you'll get a nice American made radiator that fits and was made by people who care .
    No , I no longer have thier contact info but last time I checked (10 years ago) they were still on Washington Blvd.
    FWIW , if it comes and is a three row core , that's the stock radiator with a fnacy name and higher pricetag . :eek:
    The stock three row core easily cools a 500 C.I. Caddillac engine in Death Valley.....
  9. ol' chebby
    no part #, just the 4 core radiator.
  10. mobileortho
    mobileortho Member
    Hampton, VA
    Nate are you running a V-8 or a six?
  11. Bill Hanlon
    Nate don't do bent engines.
  12. vwnate1
    Sacrilage !
    I am running a mystery 1957 passenger car 235 InLine 6 banger engine thankyouverymuch :D
    I don't touch V-ate monstrosities unless you screw a gun in my ear .
    Of course , the FREE Cadillac hearse , I'll touch that one but I'll whine like yer little kid sister the entire time , my brother says if I can find a Cummins Diesel out of a wrecked Dodge I can swap it and then have a proper InLine engine again...... :rolleyes:
