Check list
Discussion in '1947-1954' started by Guest5979, Aug 31, 2008.
  1. Guest5979
    Guest5979 Guest
    BATTERY CABLES-NEW
    SPARK PLUGS-NEW
    POINTS/CONDENCER-NEW
    CAP/ROTOR-NEW
    PLUG WIRES-NEW
    FUEL TANK-NEW
    FUEL LINE-NEW
    FUEL PUMP-NEW-N.O.S
    CARB-REBUILT
    COIL-NEW
    WATER PUMP-NEW
    GENARATOR-REBUILT-12V
    STARTER-REBUILT-6V STILL CRAPPY
    EXHAUST MANIFOLD STEEL SLEEVES-NEW
    EXHAUST GASKITS-NEW
    TRUCK RAN WHEN I PULLED ENG/TRANS TO DO FLOORS NOT GREAT BUT IT RAN.SO AT THIS POINT I DONT KNOW WHERE TO START TO GET TRUCK RUNNING AGAIN.
    THANKS
    ROBERT:confused:
  2. Bilbo
    Bilbo Member
    Magnolia, Texas
    Robert, I looked back at some of your other posts, and I see that you probably got the #1 cyl on TDC, and looks like VWNATE steered you on the correct firing order..... One thing I do a lot just to prove if the problem is fuel or electrical is add a little fuel, about a tablespoon, down the throat of the carb and then crank it. If it fires when you crank it over then, you probably have a fuel delivery problem. If it doesn't fire then, you almost certainly have an ignition problem. The four things always required to make an internal combustion engine run are: fuel, ignition, compression, and the proper timing of the other three. Hope this helps.
  3. Guest5979
    Guest5979 Guest
    Try try again
    hey bilbo
    i did put fuel in carb and nothing.
    I did pull the dizzy out of eng so i think my problms are right there when i get the time i will print all of your guys info go in the garage and start over one step at a time
    thanks again
    robert
    No Start
    Robert ;
    It's difficult to diagnose a no start over the 'phone (so to speak) but we're out here for you ~ I have this same problem occasionally and it's always some little thing I was sure I had checked , or done allready .
    Keep at it , don't get riled , take a break when it's too hot , you'll get there in time .
  5. brit 50
    brit 50 Member
    Essex England, the motherland
    Starter?
    rebuilt 6vlt starter on a 12vlt set up and its crap? should spin over faster than a G taking a corner at over 20mph!!! have you checked the earth cables from battery to chassis and engine to chassis? maybe theres a bad earth soaking up all them amps.
  6. Guest5979
    Guest5979 Guest
    6v starter
    i have to try what nate said slide the solinoid because the starter gear sounds realy bad when cranking.maybe starter gear is not making full contact.
    Starter Noise
    If thwe starter is cranking the engine but making terrible noise as it's doing so , you have the wrong starter in there ! I assume you exchanged the starter ? did it crank quieter before the rebuild ? or has it always been noisy ? .
    If you count the teeth on the ring gear , that'll tell you is the flywheel is a 6 or 12 volt one , they're different .
    Maybe they sold you the wrong one...
    I hope you remembered my advice to never turn in a core until the job is done .
