New front leaf springs
Discussion in '1947-1954' started by vegaskenn, Sep 9, 2008.
  1. vegaskenn
    vegaskenn Member
    Henderson Nevada
    Getting ready to install new front leaf springs. Got all new hardware, shackles and rear bolts. These springs are designed to achieve a 3 inch drop on the front end and might get close to 4 with the v8. Steering is stock.
    Has anyone who went this direction to drop the front have any problems?
    I thank you in advance for any comments or recommendations....Ken
  2. mikesters1950
    mikesters1950 Member
    Roseville USA
    Yep, I did it on my 1950 1/2 ton. Has a 6 cyl, with stock steering box, and 1 inch tie rod. It did lower it pretty good, and rides decent. There is some bump steer. I installed high pressure gas shocks for lowered trucks from CPP, I think it was. One problem I did have was the alignment. BE VERY CAREFULL! when driving it for the first time. I had a very SEVERE shimmy above 30mph. I almost crashed the truck. It turned out to be a caster issue. I will double check, but I think I ended up having to take out all the caster shims to get it back to the correct caster. Then it drove nice and smooth. I also installed a front sway bar. I recommend it. Good luck, and feel free to ask any questions......Mike
  3. vegaskenn
    vegaskenn Member
    Henderson Nevada
    Thanks Mike, got any pictures of your truck?
  4. brit 50
    brit 50 Member
    Essex England, the motherland
    Bump stops!
    What you got to be careful of is the axle to chassis clearance, dont want it riding on the bump stops or you will be in a whole bunch of trouble, im going for a stock axle dropped set up so i will still have plenty of suspension travel and no bottoming out!
  5. Bill Hanlon
    But beware of the tie rod banging frame or oil pan.
  6. brit 50
    brit 50 Member
    Yup!
    Got that covered:D
  7. vegaskenn
    vegaskenn Member
    Henderson Nevada
    This project has stalled a bit since I cannot break the nuts on the rear bolts to get the stinkin' original springs off. Any ideas short of putting it on a rack to get better leverage? I am also trying not to have to cut the bolts also.
    Any ideas?
  8. brit 50
    brit 50 Member
    Nuts
    Well i had a snap-on 3ft breaker bar and socket with a 6ft scaffold pole slid over it to losen my ones, and they hung on untill the last thread too, now that was a work out:D
