New, need help findings seals
Discussion in '1947-1954' started by ljjjll, Sep 17, 2008.
  1. ljjjll
    ljjjll Member
    Hi Everyone,
    Brand new here. I got a 49, 3/4 ton as my toy. Trying to fix a couple things but having trouble locating parts.
    First off, need the oil seal for the pinion bearing on the differential
    Second, need the oil seal for the one of the rear wheels. The rear axle on this is the floating type. This seal prevent the 90 weight grease in the differential from entering the brake pad area.
    If someone has an idea where to get these, it would be appreciated.
    Jim
    Welcome jim !
    Althopugh you can get the seals from our forum sponsor or Chevs Of The 40's , your best bet is to walk into your local FLAPS and have the counterman crack the Bower BCA / Federal Mogul bearing & seal book, they'll be right there .
    Same thing @ any NAPA store , you just have to find a counterman who knows how to READ A CATALOG , as there's footnotes and so on..
    Also , each and every seal has it's own part number casted into it if you look carefully before removing .
  3. ljjjll
    ljjjll Member
    Thank you.
    I did look in the online catalog, but didn't see anything. Blind I guess!!!!
    Go to part store tomorrow and try my luck.
    Jim
  4. shankamoto
    shankamoto Member
    Missouri
    seals
    These seals fit 46 to 65 chev 3/4 ton.
    GM part #3653618 pinion seal , axle seals #3743202 just for reference.:
    Nate gave you good advice.
    Yeah , Well ;
    I DO work in the parts room of a large truck shop ya know....:rolleyes:
    Sadly the retard on night shift 'cleaned up ' a while back and tossed out all my old Timken and Bower/BCA bearing and seal catalogs... :mad: this is why I didn't justpost up your part #'s Jim , sorry .
    I'd have thought they'd haveOnLine catalogs but no ~ even when I wrote them and said this is an urgent need and would increase sales , they blew me off .
    HEY ! I wonder if Chicago Rawhide has an OnLine seal catalog ? :confused:
  6. ljjjll
    ljjjll Member
    Hi,
    Thanks for all the help from both of you. GM part numbers--pretty cool.
    Jim
  7. ljjjll
    ljjjll Member
  8. sweet50
    sweet50 Member
    A R I Z O N A
    All the above posts is the reason I love this place. Everybody is always helpful
    Last Word On Seals
    Is that GM tends to have better quality seals than most aftermarket manufactureres....
    I don't know whay this is but it IS so .
    Whenever possible , order up the new seals from your local GM dealer and you'll be pleased .
