Carbby's
Discussion in '1947-1954' started by ccharr, Sep 26, 2008.
  1. ccharr
    I need some help in learning the ins and out of the carburator.
    All my out stuff is going to crap because I can not ajust them or really know anything of the carburator. :(
  2. BIG CHEVY 3600
    BIG CHEVY 3600 Member
    Dallas
    I am running a Holly 600 so I can't help you. The place to ask your question is over at www.stovebolt.com. Those guys really know their carbs.
    Which Carby Is It ?
    The venerable Rochester Series "B" is a very good , simple carby (simple ? it's bloody CRUE !) , once you've cleaned it and added a see through plastic fuel filter , you'll not need to touch it again for years ~ carbys DO NOT GO OUT OF ADJUSTMENT ! .
    How may I assist you Charles ? .
  4. Zig
    Hold yer horses!
    If you spend some time getting familiar with who's who, you'll know that Nate IS Mr. "carb"!
    No need to go to stovebolt~
  5. ccharr
    Nate,
    My truck has the carter carb on it, I need a lesson in these contraptions.
    When I take off and get to about half a thoddle it starts cutting out like it is choking for gas, more like a dirty filter. But the filters are new, the engine is just been rebuilt. It will leak gas out of it after I stop the engine, it floods real simple, going up a grade is almost impossible. Right now the truck will be gone for a week.
    Thanks,
    A Carter YF then ? it's prolly the metering rod that's causing the 1/2 throttle choking , it needs to be loosened up and gently pressed home whilst your third hand is holding the throttle closed .
    Flooding is endemic to oldies , I know you hate to modify the steel fuel lines but the fuel filter MUST be mounted to the carby inlet , then you can re-bend the steel line to suit , I just cut mine short .
  7. ccharr
    Sadly , I do not have pix but if you can find a rebuilt kit say from TOMCO etc. , it should have a detailed instruction sheet explaining the various adjustments you make before it's on the engine ~ I'll have a looksee but I don't think i haveany reference books for Carter carbys .
  9. Kens 50 PU
  10. ccharr
    Thanks Ken and Nate for the help.
    Still not sure about the carb thing.
