Suspension Derusting
Discussion in 'Chassis & Suspension' started by glaser06, May 12, 2008.
  1. glaser06
    glaser06 Member
    South Texas
    For derusting suspension parts (and wheel hubs, brakee, etc) what's the best approach? I'm wary to use acid as I don't want to cause acid embrittlement in these parts. I'm going to blast/sand down each part but still need a way to kill all the rust (I'd usually use Phosphoric acid). List of things I'm looking at:
    Control Arms
    Torsion Bars
    Wheel Hubs
    Brake parts
    Steering linkage
    Rear Springs (rear coils on 1960)
    I've seen a product called Rusteco that would work but it's something like $80 for 2 quarts. Any ideas are helpful.
    -glaser06
  2. truck_oldschool
    truck_oldschool Member
    have u tried wd-40 soak it down again and again and again
  3. glaser06
    glaser06 Member
    South Texas
    Yeah, I've WD'd the heck out of most of the parts, but that doesn't get rid of the rust. I've got most of the pieces freed up or off, I just need to clean the rust off of them.
  4. anthony j
    anthony j Member
    murfreesboro
    dont sand blast controll arms or any linkages that have joints sand will get under the boots if u do it might as replace ball joints idd use a wire wheel or sanding pads on a angle grinder
  5. cmkruse
    cmkruse Member
    SUNNY FLORIDA
    Blast - treat with OSPHO (Phosphoric Acid) let dry avoid breathing fumes- scuff to remove OSPHO surface residue if present- prime and topcoat. Light treatment with OSPHO will not cause acid embrittlement that I am aware of.
  6. bowtiecall
    bowtiecall Member
    what about products like rustoleum spray paint or por-15 I was thinkin about using either or, only after hittin the parts with a wire brush :cool:
  7. dvalentine
    dvalentine Charter Member
    Sacramento
    POR-15 is for rust encapsulation and not for the treatment of bare metal to prevent rust.
    It is meant to be applied directly to rusted material ( after knocking the big chunks off)to prevent further corrosion.
    Val
  8. bowtiecall
    bowtiecall Member
    Thanks Val Where ya at in Sac. I'm in Elk Grove:)
  9. dvalentine
    Sacramento
    I'm in Land Park !!
    Stop by Suzie's Burgers tomorrow night after 6. 30th and P Streets !! Street Rod Cruise in !!!
    Val
  10. Rich 5150 69
    Rich 5150 69 Member
    Nor Cal
  11. 63chev
    63chev Member
    salt lake city, utah
    electrolysis
    i used this method on a bunch of parts it works fantastic
    what you need:
    container big enough to submerse part
    washing soda
    water
    battery charger
    you can get instuctions off google
    i tottaly recommend this as the best way for small parts
  12. bonvo
    bonvo Member
    vacaville california
    go to kregan or ace harware they have a rust/paint removing wheel that you put on the end of a drill this thing works wonders they wear out fast but at $10 a wheel its cheap it only took me 2 wheels to strip my entire front end and one door down to bare metal
