Low $ shroud.......don't laugh!!
Discussion in '1947-1954' started by mobileortho, Oct 6, 2008.
  1. mobileortho
    mobileortho Member
    Hampton, VA
    With todays financial crisis, my budget for the truck has been virtually eliminated so I've been looking for some creative ways to save some money. With that in mind I came up with a low budget, low tech fan shroud.This is what I came up with. It's two 17x11 baking sheets I got from Walmart for $10. I cut off one side of each one, traced and cut out the hole for the electric fan and bolted the halves together. I then bolted the fan over the hole and used plastic ties to secure it to the radiator. It works good considering what it's are made of and there is plenty of clearance. I know I'll more than likely replace the radiator & get another shroud eventually, but for now I'll use this setup! Stop laughing!! :D
  2. GrandpaGlenn0
    GrandpaGlenn0 Member
    Missoula
    Looks like good old fashioned ingenuity to me!
  3. Zig
    What? No louvers???:D
    Very creative!:cool:
  4. kg4mon
    kg4mon Member
    Pineville, Ky
    Now that's what I call Hot Roddin !!!!!!
  5. Kens 50 PU
    I'm thinking chocolate chip cookies!:cool: Pretty slick idea! I'm with Zig, though. Why not put louvers, or at least drill some ventilation holes for extra cooling? I think you've stumbled on something here!!
  6. mobileortho
    mobileortho Member
    Hampton, VA
    You mean like this one? For what I'd be charged for having them punched it would no longer be low $.
  7. Bill Hanlon
    Louvers would be counter-productive when sitting still as they would allow the fan to pull SOME hot air from the engine compartment through the louvers, across the inside of the of your shroud and push that same hot air back into the engine compartment without ever passing it across the radiator. I admit that much of the air would be "new" outside air that would cross the radiator, but there would be some that was "recycled".
    Now if you would just make the louvers into shutters that automatically open when your truck is moving forward at a reasonable speed (say 10 MPH) and close below that ...............
  8. brit 50
    brit 50 Member
    Essex England, the motherland
    Like it
    Like we say over here, 'necessity is the mother of all inventions' its amazing what you can come up with and how resourcefull you can be when you need to:D
  9. Zig
    Pat. Pending # BR549
  10. Blue Bowtie
    Blue Bowtie Member
    Panama City, FL
    Cool. Nothing wrong with low budget ingenuity.
  11. 51 HHR
    51 HHR Member
    New Egypt New Jersey
    new meaning to car-b-que
  12. vwnate1
    Once again ' farmer fixing ' saves the day .
