gas pedal sticking
Discussion in '1947-1954' started by ronaldg, Oct 11, 2008.
  1. ronaldg
    ronaldg Member
    all the sudden my gas pedal wants to stick some times i have to pull it up with my foot any ideas on what the problem might be thanks
  2. mikesters1950
    mikesters1950 Member
    Roseville USA
    The most likely I would think, would be a broken return spring at the carburetor. Aside from that, you need to check for bent linkage, or something rubbing, or binding on the linkage itself. Good luck.
    P.S. If that doesn't help, let us know the exact setup you have as far as engine, tranny etc........Mike
  3. brit 50
    brit 50 Member
    Essex England, the motherland
    Gas pedal?
    you havnt named your truck Christine have you?:D
  4. Guest5979
    Guest5979 Guest
    pedal linkage
    I need to find a gas pedal linkage mine fell apart.
    any ideas where i should start my search for one???
    Robert:confused:
    Ron
    Look at the bell crank on the side of the cylinder block , often (usualy) the ends of the two rods wear bit by bit until they're floppy and so begin sticking ~ this can be a serious safety issue so take some time and have a look .
    Field repair is to add a couple thin flat washers to gusset the rods , better yet is to find new rods and bell crank or have the old one gas welded then file as needed to fit correctly . Some years used sheet metal bell cranks , these are easy to repair by welding up .
