looking for 1956 parts
Discussion in '1955-1959' started by 56stepside, Oct 5, 2008.
  1. 56stepside
    56stepside Member
    Hi All, first post for me. wondered if anyone has some of the parts I am looking for. I just started a 1956 chevy pickup. looking for front fenders, windshield, and passenger window for starters.
    Fredericksburg TX
    Windsheild ...
    ... is available new. Any auto glass dealer should be able to get one for you.
    Windshield for 1955-59 Chevy and GMC Pick-Up and Suburban is National Auto Glass Specification part #DW 407
  3. bonvo
    bonvo Member
    vacaville california
    right on another 56 stepside is yours a 1/2 ton? 3/4 ton? long bed? short bed? mine is a 3/4 longbed
  4. cowboy357
    cowboy357 Member
    Kansas
    Where are You Located ? I Have a lot of parts including Parts trucks & Project trucks. I Doubt I have a set of Perfect fenders but I,ll have to look. Thanks Bob
  5. 56stepside
    56stepside Member
    was trying to save a buck and go used
  6. 56stepside
    56stepside Member
    3/4 ton long bed. just started tearing it apart.
    where are you on yours?
  7. 56stepside
    56stepside Member
    i am an hour south of saint louis missouri, where are you? I got front fenders, still looking for windshield, doors, lots of small brakes parts... etc
  8. cowboy357
    cowboy357 Member
    Kansas
    Howdy again 56 Stepside, Curious if You found what You needed Yet. & What kind of brake parts are You looking for also ? Bob
  9. 56stepside
    56stepside Member
    hi cowboy
    i am in st. louis. heres a list of what I am looking for...
    3/4 ton rear brakes pretty much everything,
    48 nice lug nuts, cab rear corners, radio delete bar, heater w/ all defroster tubes and vents, kick panels, rear tail lights, front and rear bumpers, glove box, inside handles, bed rails, bed bolts, bed wood, emergency brake entire assembly, beehive oil assembly, brake lines, windshield and rear glass rubber, drivers side door mirror,windshield clips, battery holddown , pass. side glass.
    anything I can find to save a buck would help
  10. cowboy357
    cowboy357 Member
    Kansas
    Hi Again Dean, Just found Ya in My email , I Thought We,d Talked before . If You still have My email , will You send Me A better detailed list & Possibly some pics of the old parts, if You even have Them.
    I,m just now getting into some of the Parts I have, I,ve got several glove box doors , at least one full cab corner Repair panel . Emergency brake Handle, Possibly the Whole handle assembly . batt hold downs , inside handles I,m Pretty sure .
    Need more Detail , pics if possible, Even out of a catalog would help , for the mirror , Heater Parts , Kick panels . Any other Smaller Items that You might need , All This stuff is Mixed together & Its Hard for me to tell whats what .
    I still have 2 Fairly complete cabs I Might part out also , So Pretty sure I can help You out at least on most of the smaller stuff . Thanks again Bob .
    Also is Yours the big back Window or Small, I Might have some decent rubbers also.
  11. 56stepside
    56stepside Member
    Hi Cowboy
    first can I get your email address? shoot your emai laddress to me at deamar4@aol.com and I will give you a more descriptive detailed email on what i am looking for
  12. cowboy357
    cowboy357 Member
    Kansas
    Yep No Problem Dean We Talked before Through email , I Thought You might still have My addy. kgraggster@gmail.com . Thanks Bob
  13. chevelleman
    chevelleman Member
    Indianapolis USA
    Hello I have a windshield,front original bumper,I also have ebrake cables rear,ebrake handle,dash gauges used and nos,some bed support rails,wiper cowl grille,drivers door,front fenders,57 hood 55/56 hood, will have to look at what else I have
  14. azsnow
    azsnow Member
    Chandler, AZ
    I have a disk brake conversion kit that i will let go for $300 plus shipping. I was going to use it untill I discovered my frame had been rewelded and will now be replacing the junk part with a Camaro front clip.
  15. bonvo
    bonvo Member
    im to the point im putting it back together so i can drive it for the moment all stock i just need a truck but later in life i will rod it
