54 chevy truck cab weatherstripping install
Discussion in '1947-1954' started by bobs55.1, Nov 27, 2008.
  1. bobs55.1
    bobs55.1 Member
    devine, texas
    what is the method for installing the door opening weatherstripping into the long retainer channel that surrounds the door openning??
  2. shankamoto
    shankamoto Member
    Missouri
    Windlace
    There is a thread on page 3 that covers this.
    WINDLACE HELP ON 51 dated 11-06-2008
    Hope this helps :)
    Gene
  3. ol' chebby
    I'll be doing this soon, I will post assembly pictures as I do it.
  4. osmosisarmadill
    osmosisarmadill Member
    tulsa OK
    Thanks from all of us that learn better through pictures:p
  5. ol' chebby
    Use KY or something very slick and a friend to help pull it through. Much swearing is involved.
  6. Chiro
    Don't forget the use of many adult beverages for proper lubrication as well:D.
  7. richie d
    richie d Member
    cab windlass
    100_0092.jpg I recomend the blunt screw driver meathode it worked the best - just take your time. I found that you have to trim around the dash for a cleaner look.
  8. Zig
    Hard work!
    richie~ That's a fine lookin' truck you got going! Nice color, too!:cool:
  9. booger
    booger Member
    Schulenburg Tx
    good clean lookin truck Richie
    Windlace Tool
    Harbor Freight etc. have these nice nylon stuffing tools , they work well and won't chip the paint....
  11. Steve Katzman
    Steve Katzman Member
    Its a pain but
    I found the easiest way to get it in was with WD40 and then a very short wide blade screwdriver. It took about 30 minutes per side after I figured out the wrist flick:D
  12. vwnate1
    Wd40
    Just remember that WD40 is a solvent and will hasten the demise of any rubber / plastic product , especially the taiwanese rubber bits....
    Use silicone as long as your paint is 1000 % FINISHED as silicone will make fisheyes in the paint if it gets on the body before you paint it .
  13. Zig
    You bet!
    I really liked the way STP Son of a Gun worked getting my window glass/gaskets in.
  14. Kens 50 PU
    Goop hand cleaner works wonders too and will not warm finishes!
  15. booger
    booger Member
    Schulenburg Tx
    Ken ,goop will not "warm" ? finishes . where are you using this stuff?
  16. Kens 50 PU
    Goop hand cleaner is slicker than "snot on a door knob". 100% water soluable too. I've installed many a window, windshield etc using that stuff.
  17. booger
    booger Member
    Schulenburg Tx
    Ken i think there was humor? in there!?!
  18. Kens 50 PU
    You know the old saying "If you can't dazzle them with brilliance, baffle them with bullsh*t" Anything that needs a "little extra" to fit can be accomplished with something that is slick. Goop or "Go-Jo" works in my book!
  19. vwnate1
    Cream Typ Hand Cleaner
    Is also unbelieveably great on old Moto seats , any old stiff seat cover that's faded to white , smear it on and gently work it in with a soft britsle brush , wipe off then buff with a clean soft cloth ~ you'll be amazed .
  20. BIG CHEVY 3600
    BIG CHEVY 3600 Member
    Dallas
    Richie:
    Great looking garage! Did you put the truck in there for the photo shoot or does you wife really let you use it?:D
