Converting small to big back window
Discussion in '1960-1966' started by mhtruck, Feb 16, 2001.
  1. mhtruck
    mhtruck Member
    Hi Everyone,
    I would like to convert the small back window to a big window in in the cab of my 1966 fleetside. Other than swapping out cabs, is such a thing possible? Looking at the cab from the outside certainly makes it look like I should be able to do it. However, on the inside how would I fabricate the rolled window lip? Does anyone know if replacement/patch metal is available for such a conversion? I would greatly appreciate any help, advice, or ideas you care to share.
    For the record, I've never done metal work before but will be working with a professional fabricator (should I choose to do this).
    Thanks for your help and interest.
    Mary Helen
  2. Craig
    Craig Guest
    It would be alot easier to switch cabs.You could find a big window cab and use the panels.But they are all spot welded together.And you would find that switching cabs would be easier and faster.
    Craig Hager
    tech1@chevyduty.com
