Secret Tappered Bearings
Discussion in '1947-1954' started by breezy, Dec 2, 2008.
  1. Fla54Chevy3100
    Fla54Chevy3100 Member
    Central Fl.
    disc conversion kits
    Classic Parts of America Chevy Duty) has provided the lion's share of parts for my 54 truck but I've used Classic performance parts for some specialty items. Scroll down the page and you'll see they offer the bracket kit with spindle spacers and the correct seal for the conversion.
    http://www.classicperform.com/4754chevtrk.html#Performance Brake Kits
    Check out their site and make your own decision. Just another option.
    Dave
  2. Zig
    Thanks, Dave
    Good to know. Thanks for the site.
    I only wonder what the weight difference is between a Camaro and a 3/4? Would these Camaro disc brakes be able to safely and continually stop a 3/4?
  3. breezy
    breezy Member
    Monett Mo.
    I would say yes.If those old band brakes will stop it then disc should stop it no problem. There is alot more clamping force with disc and no fade.
  4. Fla54Chevy3100
    Central Fl.
    disc brakes
    Re: Disc brakes on pickup trucks.
    Personally, after setting up pickup trucks with rear disc brakes....I wouldn't do it again!!! Especially when you're using a power boosted system. They just work TOO well!! And that's where you wind up getting into trouble. Even with an adjustable proportioning valve, cranked down to restrict rear brake lock-up; it's the reason why modern vehicles are mostly all ABS controlled.
    With the weight distribution of a pickup as it is....front discs are great....I prefer manual discs, but boosted front discs with drums on the rear works fine if you are paying attention during heavy braking situations. The disc/disc boosted system is going to require getting your adjustable proportioning valve tuned after doing some experimenting to get your bias dialed in. Toss in a power booster and the situation gets even more touchy. Here's what I've discovered.
    During normal driving you won't have any real issues. However, during heavy braking, the driver, even strapped in securely, has a tendency to apply more pressure on the brake pedal as your body moves forward. Unless you can back off on the brake pedal you're going to naturally apply more pressure on the brake pedal. Once you lock up your brakes, control is going to be an issue. The modern abs system compensates for this extra pressure. You don't have to pump the brakes to maintain steering control. With the non-abs system, you old truck becomes the "mass" factor in an equation that can yield unpleasant results.
    For that reason, I no longer run rear discs on the old trucks and prefer manual disc/drums on a non-abs situation. I can dial down my rear bias from the cab of my truck on wet pavement to all but eliminate rear-wheel lockup.
    IMO, a good set of drums brakes in the rear will suppliment front discs and give you a much better brake control. That's my story and I'm sticking to it!!!
    Dave
    Common Sense Braking Advice
    Right on Dave ! .
    :cool:
  6. GrandpaGlenn0
    GrandpaGlenn0 Member
    Missoula
    Dave, your explanations are always so clear & logical-- thanks for taking time to make idiots like me able to understand.
    Glenn
  7. mikesters1950
    mikesters1950 Member
    Roseville USA
    rear discs
    I agree on the rear drums. I am running 4 wheel power discs, and have no issues, however, they will stop right now. I am considering going to a smaller booster to help. Rear disc brakes are a major overkill on these trucks unless you are hauling heavy, or trailer towing. One thing about 4 wheel discs...they look sweeeeeeeeet! So if you are running custom rims, that will show the brakes, I like them! Just my 2 cents worth.....................Mike
