Saginaw tranny
Discussion in '1947-1954' started by Volker, Dec 18, 2008.
  1. Volker
    Volker Member
    Germany, nearby Leipzig
  2. old blue
    old blue Member
    tranny
    That one will work but the ratio is not the best. Look for one with the correct 2 grooves on spline...it is the best with a 3:11 first gear.
    Saginaw Trannies
    So ;
    Where do I go looking for the two groove Saginaw tranny ?
    What's it's original ittment ? .
    What vehicles used the no groove tranny ? .
    TIA ,
  4. Volker
    Volker Member
    saginaw
    I talked with Patrick and he said my trans is too small (a special case in 1946) to change without cutting the driveline. It was an idea but i found now that's the original is the best. ...and i can learn to drive with the old crash box.
    Volker
  5. GrandpaGlenn0
    GrandpaGlenn0 Member
    Missoula
    Hi Volker, I believe there is a good post about double clutching here if you do a search-- if not here, then try the Stovebolt Pages--
    Have funm
  6. Blueflame236
    Hello Volker
    Maybe this is intresting reading for you? The attached link gives a very good picture about your questions.
    Happy Hollidays wisches from Martinius Berg/Norway.
    http://www.geocities.com/MotorCity/G...05/dshaft.html
  7. Blueflame236
    Hi Nate
    Some of your questions could be answered by reading this note?
    Thanks for all the good help and enjoy the X-mass.
    Martinius.
  8. Volker
    Volker Member
    Link
    Hi Martinius,
    the link don't work.....
