new distributor and timing
Discussion in '1960-1966' started by rustbucket, Jan 3, 2009.
  1. rustbucket
    rustbucket Member
    New Braunfels USA
    I don't know where to start here.
    I put in an HEI on my rebuilt 230 - 6 cyl.
    I can't remember the trick here...
    rotate the fan until the #1 cylinder is at the very bottom...or top....and point the #1 plug wire from the distributor to ?
    I know. and I haven't even had a beer yet...
  2. cowboy357
    cowboy357 Member
    Kansas
    Bring #1 Cylinder to the top of the Cylinder ( Top Dead Center ) . The Marks on The Harmonic Balancer Should also Line up to The 0 Mark . Then The Roter In the Distributer should be pointing torwards the The #1 position on the dist cap Where #1 Plug wire goes on. At Least to the Best of My Memory, Hope that Helps & Good Luck. Bob
  3. rustbucket
    rustbucket Member
    New Braunfels USA
    Thanks Bob...i knew there was a trick to it
  4. Rich 5150 69
    Rich 5150 69 Member
    Nor Cal
    One quick way to set timing, remove coil wire, ensure #1 is on firing order, and set at what ever timing mark you want, drop distributor in, hookup # 1 plug wire and timing lite (battery powered) turn key on and rotate distributor until lite flashes. Stop and lock it down your timed....
  5. rustbucket
    rustbucket Member
    New Braunfels USA
    MAN i wish you guys lived close.
    I would provide all the beer and bbq you wanted to help me get this thing started...
  6. Arlo
    Arlo Member
    Tomball, Texas
    If you have the #1 cylinder up "pull the plug use a pencil and feel the top of the piston dont drop the pencil roll the motor up till the pencil is at its farthest point out. the point the distr. at the #1 cylinder. remember you have an exhsaust stroke and an intake stroke. so you want the intake stroke otherwise you are a 180 degrees out. timing marks on the balncer will help to line up zero if you have it. i think im rambling hope this make sense i have had a few cold beers tonight.
  7. dcsi5919
    dcsi5919 Member
    Kansas City United States
    I purchased a remote start trigger that attaches to the starter. After it is correctly attached, remove the #1 spark plug and use the trigger starter to advance the motor through the compression and exhaust strokes with your finger over the plug hole. When it burps air out of the plug hole you are at tdc. Run through the cycly a few times to ensure you are at tdc. The remote trigger starter really helps with the process, especially if you are working alone. You can purchase one for around $10.00 at your FLAPS.
  8. 66 KUSTOM
    66 KUSTOM Member
    SALEM OR
    i work on new foriegn cars as a daily job and i still use the classic way of finding #1 top dead center, i pull out the spark plug, stick my finger over the hole, have a buddy turn over the moter with the key untill my finger blows out, then i back the crank up to 0. then just follow what cowboy357 said.
