62 motor mount perches
Discussion in '1960-1966' started by bowtiecall, Jan 4, 2009.
  1. bowtiecall
    bowtiecall Member
    any suggestions for installation of v8 perches on a 62 frame with no holes in frame previous engine was a 6 cyl also goin with th350 from a 3 on the tree will the tranny fit? it also has the low hump. thanks:confused:
  2. Arlo
    Arlo Member
    Tomball, Texas
    Tranny will fit. dont know what to tell you on the mounts other than measure twice and drill. I can get you the measurements this evening if you like
  3. bowtiecall
    bowtiecall Member
    will the aftermarket perches for a 63 fit this frame:confused:
  4. Arlo
    Arlo Member
    Tomball, Texas
    not sure maybe DValentine can answer this for you. what are you going to do with the inline 6?
    Does it run? Dispalacement? i would be interested.
  5. bowtiecall
    bowtiecall Member
    ran like a top I sold though it was a 235
  6. Arlo
    Arlo Member
    Tomball, Texas
    never know till you ask thanks though
  7. dvalentine
    dvalentine Charter Member
    Sacramento
    There are some aftermarket perches that are advertised for 64-66 trucks that will fit with some work. I can't remember "who" makes them but will make a point of looking it up.
    Val
  8. cowboy357
    cowboy357 Member
    Kansas
  9. dvalentine
    Sacramento
    Yea, that's them.. They were/are manufactured by someone else, who I was trying to remember. I see the"other" truck supplier, who is NOT one of your SISTERS, picked them up. ;)
    Val
  10. colettesbro
    colettesbro Member
    Owatonna, MN contact info: cell 507.456.3625 email
    Sixty Two,
    If you haven't found motor mount stands for your 62 yet, I have 3 or 4 pair available. Yes, you will need to drills holes on your 62 frame.
    Here is pictures of some.
    http://good-times.webshots.com/album/562519931YZHuGM?start=36
    Here is photos with comments below photos of how I installed them on my 1961 (V8 with TH350 tranny).
    http://rides.webshots.com/album/562303409RqEyqn?start=48
    Brian
    cell 507.456.3625
