Backup light switch
Discussion in '1960-1966' started by ottoman562, Jan 10, 2009.
  1. ottoman562
    ottoman562 Member
    Mountain Brook, Al
    Hey Guys,
    Has anyone changed a backup light switch on a 3 on the tree? Do you have to take the column apart? Where exactly is the switch mounted?
    Oz
  2. 66 KUSTOM
    66 KUSTOM Member
    SALEM OR
    what year, which transmission do you have?
  3. ottoman562
    ottoman562 Member
    Mountain Brook, Al
    '66, I think its a Muncie...Truck has 250 L6 , original motor and I believe original tranny....
  4. 66 KUSTOM
    66 KUSTOM Member
    SALEM OR
    ok, i believe the switch is screwed into the side of the tranny. look for green wires going to the tranny and youll find the switch. correct me if im wrong, i might be thinking of a floor shift tranny.
  5. dcsi5919
    dcsi5919 Member
    Kansas City United States
    Oz:
    If you are running a factory colunm shift 3-speed manual transmission, the reverse light switch is on the lower portion of the column, near the floor board, facing down. It is similar to the neutral safety switch on the factory automatic steering columns. If I remember correctly, there are two wires feeding this switch...a dark green and a light green, that feed the reverse lights. There is a small pin that projects out of the switch, into the column mast jacket and it is rather fragile.
    If it is there, remove the two screws, that secure it to the mast jacket and inspect it. If the pin is in place and sliding back and forth freely, trace your wiring for problems. If it is not there, you can purchase them from the web host and trouble-shoot from there.
    Good luck with your project.
  6. ottoman562
    ottoman562 Member
    Mountain Brook, Al
    LILRED,
    Buddy you know your stuff, exactly where you said it would be., of course its amazing how many times i stuck my head under there while stripping the floor and adjusting the clutch pedal etc and never noticed it under many coats of black paint :rolleyes:
    Thanks everyone for the help...
