Distributor
Discussion in '1947-1954' started by ronaldg, Feb 1, 2009.
  1. ronaldg
    ronaldg Member
    Hey guys I found a used distributor in my garage it looks just like the one in my truck. which is a 235 and wanted to know if a 235 and a 216 distributor are the same I know my dad had a 41 chev pickup and it had a 216 in it so i think this is one he took off of his 216. thanks for any help
    Dizzy Fun
    The same ? NO .
    Interchangable ? oh , Lordy ~ YES INDEEDY ! ;)
    The '41 ~ '46 dizzy has two terminals for the coil wire as those all had a current reversing switch connected to the starter pedal , it caused even wear on the contact points and was soon dropped as Delco was in danger of never selling replacement ignition points ever again.... :rolleyes:
    Breaker Point & Ign. timing is the same on every InLine 6 Banger GM ever made (including the wretched Pontiac OHC) :
    Points to .016" or 33° dwell and ball on pointer @ 600 RPM idle speed or (better yet) use the triangle mark (TDC mark) to set the all-in ignition timing to 30° ~ 32° all in @ 3,000 RPM's .
  3. ronaldg
    ronaldg Member
    thanks nate
    So i have a spare good news thanks again nate.
    Used Dizzy
    Remember to always use a dwell meter when setting the points gap , if the dwelvaries by more that 3° when revving the engine it's time to try the other dizzy or sent it out for re-bushing .
    Remember : a .001" change in the points gap changes the ignition timing by 3°
    and that's a lot .
    Always drop two or three drops of engine oil down the dizzy's center shaft after removing the rotor , do this once a month or so regasrdless of milage ad it lubricsts the advance mechanism , very important for good power and throttle response .
  5. Keystoner
    Keystoner Member
    Pennsylvania
    Interesting
    As Chevy has always used Cast iron camshafts and steel gears like every other vehicle manufacturer on Earth , with no troubles .
    However , if Tom says there can be problems , I'd listen .
    both steel and cast iron go ' thunk 'if they're swadjed tightly into place , that dampens the ring .
    Looks like you alls are teaching me again .
