making noise
Discussion in '1947-1954' started by booger, Feb 3, 2009.
  1. booger
    booger Member
    Schulenburg Tx
    is there supposed to be some sort of insulator (washer) beneath the horn contact assembly. my horn would sometimes stick, so i took the button off and removed the assy. to clean up and check things. there were some remains of some sort of washer beneath it . shop manual and assy. manual do not indicate this. any help out there? kinda of nuisance when you hit the horn and it keeps blowin , SWMBO would duck down and hide when this would happen, me , i would just wave at everybody like i knew them :D
    Not that I can recall .
    Look in the parts book illustrations over on The Old Car Manual Project .
  3. shankamoto
    shankamoto Member
    Missouri
    Horn contact
    There is no washer under the horn contact assy. There are three rivets that hold the assem together and they are insulated by a paper type insulator. Use an ohm meter to check to see if the rivets are making contact with the metal plates. If you get a reading on the meter, replace the contact assem.( you will have to wiggle the contact to make sure it's not shorting out).:)
    Gene
