New motor
Discussion in '1947-1954' started by kg4mon, Feb 16, 2009.
  1. kg4mon
    kg4mon Member
    Pineville, Ky
    Hey guys, haven't been here in a while figured I'd drop in and say hi. And show you what I've been working on this winter.
  2. Larrys 48
    Larrys 48 Member
    Spokane, WA
    Sweet! Is it still a 235?
  3. kg4mon
    kg4mon Member
    Pineville, Ky
    No, it's a 250 but I'm going with a 216 alum finned valve cover.
  4. Bryan
    Bryan Member
    Tiny Town, Colorado
    WOW! Great job...Thats what I am looking to do as soon as I get a new engine :(....
    Wah hoo !
    You can always tell a Thinwall 6 Banger as the dizzy is in the front wheras a 216/235/261 has it in the middle of the block....
    Looking mighty good there ! .
  6. kg4mon
    kg4mon Member
    Pineville, Ky
    Here are some specs on the motor: Crank has been knife edged, balanced, forged pistons w/domes, 11.25 to 1 compression, 1.94, 1.60 valves, head has been ported and polished and lump ports installed in the intake runners. The head flows 285 cfm compared to the stock 170cfm. Aluminum intake with 3 deuce carbs (demon 98 retro strombergs) 205cfm each, Competition Cam .536 lift, and roller rocker arms with screw in 7/16 studs. This motor went together with alot of help from Larry at T6 racing in florida ( he specializes in 6 cylinders), comp cams and everyone I talked to said this motor should make around 425 h.p. I will be tickled if it makes 350.
    Wow !
    Just the head work alone will make it a great driver ! .
    I believe if improving flow on ALL engines , then there's no need to bump it up into Hot Rod territory where the service life is greatly diminished .
    The Chevy 250 thinwall InLine 6 Banger is indeed a GREAT engine .
  8. mobileortho
    mobileortho Member
    Hampton, VA
    Just one word for ya.......SWEET!!!!!
  9. ccharr
    Thanks that is great looking.
